STU175
Golf mk1 1984 k-jet vacuum system differences??? Help!!
Hi all not a corrado but hope some one can help me AGAIN!!
just recently fitted replacement engine to my mk1 and have noticed that the vacuum system seems to be connected different on both engines?
the engine i took out did not have a carbon canister or the 2 valves that mount to suspension turret.
the engine i installed has the two valves but no carbon canister.
i have been trying to study photos online but can never quite make out where they all go and is hard to find 2 photos connected the same ????dontknow.gif
i found this diagram but because i dont have a carbon canister how is best to connect it all up? as vw intended or different
where would No. 38 go?
do i need the 2 valves?
and there is a yellow vacuum tube coming from a valve mounted to the airbox, where is that fed??????
I was hoping someone here could help as other golf forums dont seem as helpful as this one
thanks stu
