stevef182
which rear brake pads for VR6
ok so the dimensions are different:
set 1: Dimensions H:52.9;W:86.8;T:15.2
set 2: Dimensions H:52.9;W:86.8;T:17.2
so which ones do I need? Thanks
According to VW Spares for 1989-1993 cars up to Chassis No. 50-P-009000 they are 15mm thick and later cars are 17mm thick.
Ian.
Just seems strange that the thicker ones are cheaper?
So my rado is 1993 - 15mm or 17mm? Or do I just need to check the chassis number?
Best check the chassis no to be sure where the cutoff was, Steve. Mine has the 17mm ones, but it's a 1996. Would think yours should be 15mm though.
Hello mate, howz things? On my way home the noise almost stopped, completely. All i can hear now is a very light grazing noise, even with both windows open, so i got the car into the garage and got some light on the situation and all pads, front and rear have plenty of life left. I can only imagine a small stone or similar got in somehow and has now worked its way out.
Not bad thanks, mate. You OK?
Sounds like it's sorted itself- always nice when that happens- doesn't happen often enough though!
I'm thinking maybe the late corrados had mk3 calipers and the early ones had mk2?
I'm using mk4 calipers and mk3 pads.
