olly elworthy 0 Posted February 25, 2004 just been on the sns tuning site, and seen that is possible to use a crank pulley off of a passat to increace the peed the charger rotates as oppse to a smaller charger pulley, wondering if its cheaper, and will look stock, apparentley the pulley is 3MM larger at the crank, heres the part no 92 G60/Passat "3mm larger" main crank pulley (VW p/n 037 105 255) http://www.snstuning.com/ Quote Share this post Link to post Share on other sites
h100vw 0 Posted February 25, 2004 Have a think about how much larger that is as a percentage. Supposing the pulley were 100mm in diameter, a 3mm increase would only be 3%. I think that wouldn't amount to much of an increase in boost. Gavin Quote Share this post Link to post Share on other sites
GazzaG60 0 Posted February 25, 2004 isn't the pulley difference for their non aircon models? im not sure but if it is its likely thatwe already have this unless you have airocon. just get a 65mm and dont worry about the crank one. plenty of boost with that probly more cost in a crank pulley than a charger one. Quote Share this post Link to post Share on other sites
