odub 0 Posted April 2, 2011 Mine has spat its pips so I'm after another one and possibly an engine wiring loom too. Thanks Quote Share this post Link to post Share on other sites
16VG60 1 Posted April 3, 2011 I have a 9a ECU that also comes with immobilisor box and key transponder so it can be plug and play. I want £65.00 for the lot plus postage or collect from me in Sussex. Sent from my iPhone using Tapatalk Quote Share this post Link to post Share on other sites
stereoflaver 0 Posted April 3, 2011 I have one without an immobilisor £60 posted. Part number is 8AO 907 404 C C Quote Share this post Link to post Share on other sites
odub 0 Posted April 4, 2011 Thanks guys. Hopefully I've got one in the post but if not I'll get back to you Quote Share this post Link to post Share on other sites
odub 0 Posted April 9, 2011 Could I take the ecu from you stereoflaver? The part number matches with mine Quote Share this post Link to post Share on other sites
T4ROX 10 Posted April 14, 2011 Could I ask where the immobiliser box is located on the car I think mine might be playing up as I get an initial fire then the whole engine cuts out. Thanks Quote Share this post Link to post Share on other sites
CazzaVR 0 Posted April 14, 2011 Remove the driver's dash undertray. Follow the reader coil black wire from the ignition to the little black box (see the pic in the second post above). Disconnect and spray the plug with WD40. Plug/unplug/spray a few times and this will sort it if it was just dirty. Worked on mine ;) Quote Share this post Link to post Share on other sites
T4ROX 10 Posted April 16, 2011 After many people giving varied theories, I tried the WD40 on the plug, then re-sync and bam it started. VERY VERY Happy. Thanks CazzaVR Quote Share this post Link to post Share on other sites
CazzaVR 0 Posted April 16, 2011 No worries! Glad it's sorted 8) Quote Share this post Link to post Share on other sites
