odub
2.0 16v 9a ecu
Mine has spat its pips so I'm after another one and possibly an engine wiring loom too. Thanks
I have a 9a ECU that also comes with immobilisor box and key transponder so it can be plug and play. I want £65.00 for the lot plus postage or collect from me in Sussex.
Thanks guys. Hopefully I've got one in the post but if not I'll get back to you
Could I take the ecu from you stereoflaver? The part number matches with mine
Could I ask where the immobiliser box is located on the car I think mine might be playing up as I get an initial fire then the whole engine cuts out.
Thanks
Remove the driver's dash undertray. Follow the reader coil black wire from the ignition to the little black box (see the pic in the second post above). Disconnect and spray the plug with WD40. Plug/unplug/spray a few times and this will sort it if it was just dirty. Worked on mine ;)
After many people giving varied theories, I tried the WD40 on the plug, then re-sync and bam it started. VERY VERY Happy. Thanks CazzaVR
