nommie 10 Posted April 3, 2011 hi The coolant flange on the side of my 2litre 8valve block has started to leak water. Is this an easy fix? and if so where is the best place to get the part? all help much appreciated. Thanks Quote Share this post Link to post Share on other sites
Zeal 0 Posted April 3, 2011 vw i'd say if they still do them, mines leaking too so i bought a eurocarparts one for my 1.8 16v and it's a simple reducer pipe (not bolted) you can get a 90* angled reducer, pipe connector and straight length hose from sfs hoses which will replace the parts nicely. Quote Share this post Link to post Share on other sites
mr.ots 10 Posted April 3, 2011 I'd definately get a genuine VW one. The GSF and similar don't seem to last too long before they are leaking again. Quote Share this post Link to post Share on other sites
nommie 10 Posted April 3, 2011 is it common thing to go wrong? Quote Share this post Link to post Share on other sites
Supercharged 2 Posted April 4, 2011 Yep - usually need changing every 80k miles or so Quote Share this post Link to post Share on other sites
davidwort 0 Posted April 4, 2011 If they're both original I'd do the front one too while you have the coolant drained down, the one's I got from GSF seemed pretty good TBH and were only a few quid each including o-rings, you might find the front ones are only available with two sensor holes, so watch that, the corrado only has one sensor, I've a second unused sensor filling the other hole :) Quote Share this post Link to post Share on other sites
Supercharged 2 Posted April 4, 2011 If they're both original I'd do the front one too while you have the coolant drained down, the one's I got from GSF seemed pretty good TBH and were only a few quid each including o-rings, you might find the front ones are only available with two sensor holes, so watch that, the corrado only has one sensor, I've a second unused sensor filling the other hole :) They should sell you a bung and extra O ring with it - on ETKA it's listed as 'also use...' Quote Share this post Link to post Share on other sites
groundforce 0 Posted April 4, 2011 Had the same problem with my 2L 16V when I bought it,the flange had a crack all up the side off it.VW still have them,not too pricey either. Quote Share this post Link to post Share on other sites
daleyboy 0 Posted April 5, 2011 Hehe. Flange. That was the only reason i read this thread, im disappointed now.................. Quote Share this post Link to post Share on other sites
nommie 10 Posted April 5, 2011 iv got my local garage to order me the new bit. i take it the o ring will come with it? Quote Share this post Link to post Share on other sites
daleyboy 0 Posted April 5, 2011 They im sure will order the right parts, although VAG supply parts like that separately .............. Quote Share this post Link to post Share on other sites
thermal 0 Posted April 5, 2011 Ive got a brand new Kr or 16v one if anyone wants it? Quote Share this post Link to post Share on other sites
