burn-rubber-not-soul
HELP engine mount
hello ppl i this sound bit silly but i just wanna check....
am sure the front mount has gone or its lose i in sat the car hand brake up tryed pull away i could see the engine lifting up from the front sooo that would be the front mount yes ???
Yeh, should be a little movement, but only a few mm. Worth changing the front mount anyway to be sure. Pretty easy job.
Get a Vibratechnics- fit and forget. Worth the extra dosh. Had a couple of solid mounts in the past and found the extra vibration minimal. However, got a little scared by the stories of brackets shearing off etc!
