paulg60 0 Posted February 27, 2004 which air filter is best a std panel , performance panel or a cone filter. i ask this question not for performance gains but to protect my charger from unwanted bits getting sucked in. Quote Share this post Link to post Share on other sites
Tempest 0 Posted February 27, 2004 Panel filter for the G60! If you do want to play around a bit with filters than you can't really go wrong by getting a K&N replacement panel filter. You're right in assuming it's all about your G-Lader, as non force-induced engines can cope with nastier filters (Pipercross et all) that let through more fine particles. Tempest Quote Share this post Link to post Share on other sites
W3RKD 0 Posted February 27, 2004 imho the good old std air box & k&n panel filter combination works very well allways top on my list... :-P Quote Share this post Link to post Share on other sites
Tempest 0 Posted February 27, 2004 Just OT: viel achievment bildete wenig Spitze mehr nicht zu viel. What are you trying to say, mate ? :wink: Tempest Quote Share this post Link to post Share on other sites
Bean 0 Posted February 28, 2004 What about on a vr6 then? Is that still the best plan? Does a k&n panel filter make that much differance? Quote Share this post Link to post Share on other sites
brian g60 corrado 0 Posted February 28, 2004 it makes a slight differance,but its best to make up a cold air inlet .as darren would suggest,buy some guttering pipe and acouple of bends from homebase ect.then remove carbon canister,and use this hole to tap into the air scoop for the brakes. nice mod and cheap and easy to do at home. :) Quote Share this post Link to post Share on other sites
Bobbywhacker 0 Posted February 28, 2004 being slightly thick n having no manuals what so ever, what does a carbon canister look like? And erm.. what does it do? Quote Share this post Link to post Share on other sites
Bobbywhacker 0 Posted February 28, 2004 Also, are the HKS universal power flow induction kits worth all the praise? Quote Share this post Link to post Share on other sites
beavis 0 Posted February 29, 2004 he carbon canister collects and stores any evaporated fumes from the fuel tank when stationay or excess fumes build up. When the engine is started a vacume hose opens a purge valve and draws the fumes into the inlet manifold for them to be burned off. Ourself here at Pitstop/G-werks are very envioromentaly unfriendly, we pull the carbon canister out and give it back to the customer as a gift allowing fresh air flow to the airfilter. Enviroment vs. BHP....BHP wins. The best and most hypercritical sticker i've seen on a customers G60 is 'Don't buy Esso, they kill the planet'..... and a G60 does'nt?LOL Quote Share this post Link to post Share on other sites
Bobbywhacker 0 Posted February 29, 2004 hmmm okey doke.... literally just take it off then? Quote Share this post Link to post Share on other sites
beavis 0 Posted February 29, 2004 Yes, but you have to blank all vacume hoses that lead back to the manifold but leave the bigger fuel tank vent hose to go to air. Quote Share this post Link to post Share on other sites
