James14100 10 Posted April 26, 2011 My mfa works as is should in all aspects but the oil temp never shows a reading. I've checked the plugs at the back and they are all fine. The water temp gauge works fine. Where is the oil temp gauge located so I can check it's plugged in correctly or if not replace it Cheers James Quote Share this post Link to post Share on other sites
domwells27 0 Posted April 26, 2011 Its located just on top of the oil cooler, where the oil pressure switch is. Should have a green/black wire coming out of it. Assuming its a G60?? Quote Share this post Link to post Share on other sites
James14100 10 Posted April 26, 2011 Hi Dom, yeah on my G60. I shall investigate further, cheers Quote Share this post Link to post Share on other sites
davidwort 0 Posted April 26, 2011 corroded and broken wiring at the spade connector to the switch on top of the oil filter housing I reckon, temp switch is the small one (17mm? hex), pressure warning switches are bigger (22mm? hex) Quote Share this post Link to post Share on other sites
dannyboy 0 Posted April 26, 2011 yep one closest to the front of the car on top of the filter housing Quote Share this post Link to post Share on other sites
