tim20vt
wanted right rear 1/4 glass
i need a right rear 1/4 glass,if you have one in a car your breaking and will have a go at cutting it out,if not i can cut this out myself but closer to yorkshire the better let me know if you can help.
cheers
Edited by tim20vt
I have but im a fair way from you, would have to post.
Cut what out though? I assume its just the glass youre after?
the glass and seal are bonded in to the car, you must cut the glue without damaging any of the seal as this is part of the window the seal and glass are one unit you cannot split them. if the seal gets damaged its useless.
but if your in leicester and i cant find one i would have to drive down unless you think you can get it out.
cheers tim
i think i can get it out. bit shy of time at the mo so will crack on with it next week.
