87 Jetta 16v 0 Posted May 11, 2011 Nice one cheers neal :) might save some paint Hi Chris, unfortunately the wing has a scratch about 6 inches long on it, so probably not the best for you. N. ---------- Post added at 09:28 PM ---------- Previous post was at 09:26 PM ---------- Could you do £100 posted for it if the part number is right for the fan controller?! The fan controller part number is 357 919 506 To be honest with you, the £109 is a good price so I would like to hold out for that. Thanks, Neal. ---------- Post added at 09:29 PM ---------- Previous post was at 09:28 PM ---------- I found a supply for the Fuel flap component so don't go taking it apart!!! Thx :D No worries, I had a suspicion it might break on removal anyway!! ---------- Post added at 09:31 PM ---------- Previous post was at 09:29 PM ---------- I'm still interested in the bonnet depending on condition etc, any joy with pics?. Ok for collection as you are only in Reading I believe. Hi there, The bonnet is in reasonable condition apart from one small patch which looks like it was cleaned with a washing up scouring pad so probably not ideal:( I am indeed just outside Reading. N ---------- Post added at 09:34 PM ---------- Previous post was at 09:31 PM ---------- Hi I am looking for the centre section of the dash,which the radio/heater controls and ash tray etc fit onto.(See pic) It has to be mint no broken lugs or fixings!! Also heater controls and heater(I will get back to you with what I`m after exactly)Doing an early to late swap and the heater appears to be different from the slide controlled version. A headlight switch if it works on all settings ??? Hi there, Unfortunately the centre console is not in the best condition. It has a crack in it and from memory, one of the lugs is broken to secure the heater controls. Quote Share this post Link to post Share on other sites
lilfuzzer 1 Posted May 11, 2011 Fair enough bud if I am near you and you still have them I'll take a look cheers for getting back to me Quote Share this post Link to post Share on other sites
too hot 0 Posted May 11, 2011 Hi Chris, unfortunately the wing has a scratch about 6 inches long on it, so probably not the best for you. N. ---------- Post added at 09:28 PM ---------- Previous post was at 09:26 PM ---------- The fan controller part number is 357 919 506 To be honest with you, the £109 is a good price so I would like to hold out for that. Thanks, Neal. ---------- Post added at 09:29 PM ---------- Previous post was at 09:28 PM ---------- No worries, I had a suspicion it might break on removal anyway!! ---------- Post added at 09:31 PM ---------- Previous post was at 09:29 PM ---------- Hi there, The bonnet is in reasonable condition apart from one small patch which looks like it was cleaned with a washing up scouring pad so probably not ideal:( I am indeed just outside Reading. N ---------- Post added at 09:34 PM ---------- Previous post was at 09:31 PM ---------- Hi there, Unfortunately the centre console is not in the best condition. It has a crack in it and from memory, one of the lugs is broken to secure the heater controls. Cheers thanks anyway Quote Share this post Link to post Share on other sites
elnigel 0 Posted May 13, 2011 Hi mate, do you have the handbrake cover/ gaitor, the lower bit that fastens to the bit where you hold it? If you do, is it black? Cheers, Nigel Quote Share this post Link to post Share on other sites
87 Jetta 16v 0 Posted May 13, 2011 Hi Nigel. The handbrake cover is split at the bottom so I guess that is no good? It is black though. Quote Share this post Link to post Share on other sites
GOLDTHORN 0 Posted May 14, 2011 Hi these parts still available and at what price ? Wishbone in good condition ? MARK Quote Share this post Link to post Share on other sites
adwhitt 0 Posted May 14, 2011 Hi I don't suppose you have the mechanism for the passenger door? also if the gear know and gator are in goon condition then i'll take those as well. Thanks Adam Quote Share this post Link to post Share on other sites
87 Jetta 16v 0 Posted May 14, 2011 Hi these parts still available and at what price ? Wishbone in good condition ? MARK Hi Mark, I have the suspension uprights, they are in good working condition. I would be looking for £35 posted for them if that helps? I don't have the wishbones at the moment as I might be needing them. Let me know if that helps, N. ---------- Post added at 09:16 PM ---------- Previous post was at 09:12 PM ---------- Hi Adam, Are you talking about the electric window mechanism? If yes, I do have this and it is in perfect working condition. The gear knob and gaitor are also in good condition too. Thanks, Neal. Quote Share this post Link to post Share on other sites
GOLDTHORN 0 Posted May 15, 2011 Hi Neal . I dont need the hubs and bearings if you are including those and also lighten the parcel ! I am collecting parts , with some new, to build up complete front suspensions with bigger brakes to swap over on to my car that is getting a bit flabby . So I`ll use my existing hubs with all new bearings . MARK Quote Share this post Link to post Share on other sites
too hot 0 Posted May 15, 2011 Do you still have the mfa stalk and the lower ignition cowling? Quote Share this post Link to post Share on other sites
87 Jetta 16v 0 Posted May 15, 2011 (edited) Hi Neal . I dont need the hubs and bearings if you are including those and also lighten the parcel ! I am collecting parts , with some new, to build up complete front suspensions with bigger brakes to swap over on to my car that is getting a bit flabby . So I`ll use my existing hubs with all new bearings . MARK Hi Mark, I will have some front suspension but I don't know what it is yet as it's not off the car. I'll let you know once it's off. Thanks, N. ---------- Post added at 10:14 PM ---------- Previous post was at 10:12 PM ---------- Do you still have the mfa stalk and the lower ignition cowling? Hi there, I do have the MFA stalk, but the cowling has screw holes in it. I have a brand new pair of VW cowls that I believe are NLA from the dealers if that helps? Oh, and I also have a late headlight switch if you still need one. Thanks, N. Edited May 15, 2011 by 87 Jetta 16v Quote Share this post Link to post Share on other sites
NewbridgeJob 0 Posted May 15, 2011 Hi matey, have you got the rear boot plinth (plastic bit behind rear number plate) I'll have it off you if its not cracked etc Cheers Quote Share this post Link to post Share on other sites
adwhitt 0 Posted May 16, 2011 [/color]Hi Adam, Are you talking about the electric window mechanism? If yes, I do have this and it is in perfect working condition. The gear knob and gaitor are also in good condition too. Thanks, Neal. Hi Neal Sorry I meant the actual door lock mechanism, that the outer handle pushes against to open the door. Cheers Adam Quote Share this post Link to post Share on other sites
87 Jetta 16v 0 Posted May 16, 2011 Hi Neal Sorry I meant the actual door lock mechanism, that the outer handle pushes against to open the door. Cheers Adam Hi Adam, It looks like someone has beaten you to it on edition 38. I made the offer last night. If he doesn't come back in a couple of days I will drop you a message. Thanks, N. Quote Share this post Link to post Share on other sites
Peebee 0 Posted May 17, 2011 I'm in need of a complete ignition barrel and bellow switch, keys and if poss maybe even the boot lock too. My rado door handles are delocked so door locks are not needed. Can you help and at what price? Cheers. Quote Share this post Link to post Share on other sites
87 Jetta 16v 0 Posted May 19, 2011 Hi there, To be honest I was going to sell the door handles with the keys. The ignition barrel is a real pain to get out from memory so I wasn't going to remove it, it's just a time thing really... Quote Share this post Link to post Share on other sites
Peebee 0 Posted May 19, 2011 No worries buddy, cheers anyway. Quote Share this post Link to post Share on other sites
rixy 0 Posted May 19, 2011 do you have drivers front indicator?? Quote Share this post Link to post Share on other sites
87 Jetta 16v 0 Posted May 20, 2011 do you have drivers front indicator?? HI there, I do, your for £15 collected or £20 posted if that helps? Thanks, Neal. Quote Share this post Link to post Share on other sites
hunty 10 Posted May 20, 2011 hi do you have a good passenger wing if so how much posted buddy Quote Share this post Link to post Share on other sites
87 Jetta 16v 0 Posted May 24, 2011 Hi there, The wings are only fit for the crusher i'm afraid :( Quote Share this post Link to post Share on other sites
hunty 10 Posted May 24, 2011 do you have the drivers wing in good condition Quote Share this post Link to post Share on other sites
87 Jetta 16v 0 Posted May 24, 2011 do you have the drivers wing in good condition Sorry, this one is no good either. List at top updated, though I am sure there will be parts that I have missed that I still have. Please ask. THanks, N. Quote Share this post Link to post Share on other sites
Roan 0 Posted May 24, 2011 Looking for the boot hinge covers (black plastic) if you have them Quote Share this post Link to post Share on other sites
87 Jetta 16v 0 Posted May 24, 2011 Looking for the boot hinge covers (black plastic) if you have them Hi there, Sorry, I don't have these :( Quote Share this post Link to post Share on other sites
