kingkenny100
engine mounts
At my last MOT I got an advisory that I need new engine mounts so have been on the look out for some. Iv read lots about upgrades but not looking spend a lot so was checking out ebay, there is a set of engine mounts which look quite differnt to what I thought engine mounts should look like! can anyone confirm if these are the correct part??
Thanks
http://cgi.ebay.co.uk/VW-CORRADO-VR6-SET-ENGINE-GEARBOX-MOUNTS-GOLF-COMPLETE-/220754451958?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item3365fd9df6
Those are the brackets, not the actual mounts. Don't buy cheapy replacements- false economy. Either go VW or invest in some Vibratechnics or VF mounts. You can also get a set of poly inserts from German Ebay, that will do a good job, but will be pretty cheap. You use them with the old mount housings.
