sexybourbon
advice with anti roll bar
need some advice guys , iv just replaced the passenger side lower arm bushes tonight with powerflex ones managed to do this all with little fuss but the antiroll bar bush was that corraded it snapped almost instantly! the bolt that goes straight through was literaly half its normal width in the middle and you could see the twist in it where i had tried to remove it ,
i just want to know whats the best new bush to go for , would it be standard corrado part , is there any tt or r32 ones that work or shall i just powerflex these asweal
any advice guys im not great with wat parts for what and all that
cheers
if you have polybushed some parts, I would polybush them all. Else the polybushes will take a lot more strain, and then the softer bushes will wear out much faster as they're not as strong.
So my 2p is poly everything now that you have started.
Cheers bud i did think that last nite but wasnt sure if there was another vw part that might have done the job just a little better
Ill give powerflex a ring and see what the damage is
