hawwy
help please corrado vr6
hi
im not sure if this happens when cars cold or all time BUT for the past 2 days while drivingg my corrado VR when i boot it , sometimes the car jerks? so the power dies out for a second then comes back? it just jerks when putting foot down regardless of gear etc.
what could it be?
thank you
Edited by hawwy
what would it most likely be mate?
also i was wondering , will a golf 2.8 vr6 coilpack be okay? or can you only use corrado 2.9 coil packs?
cheers
if you dont know when the HT leads were last replaced? get them replaced, you can get a cheap set for around £40.00 which will do the job, you will need to buy a vag HT lead removal tool {cost about £15.00} to install/remove them.
