Portent
How do I edit my signature?
Sorry if this is obvious but I just can't see where I edit my signature. Any pointers would be appreciated, thanks :)
Click on settings near the log in button then scroll down and it says edit signature etc on the left hand side in the 3rd box down ;)
i have been trying to update the old link in my signature but keep getting the following message:
Your signature contains too many lines and must be shortened. You may only have up to 5 line(s). Long text may have been implicitly wrapped, causing it to be counted as multiple lines.
Edited by fla
I've just edited the link to Google as a test and that worked ok. How big is the link you are trying to use? Could always use something like TinyURL to shorten it if it's too large.
much appreciated :) How do you shorten the links, out of interest? I was simply copying and pasting that into the same place i had the old one, and getting that error message...
I didn't shorten anything - all I did was use the second link you posted above. Go to edit it again and see what it looks like ... :)
