hawwy 10 Posted June 5, 2011 which is best 6 branch manifold? where can i buy it? does it need to be heatwrapped m when heatwrapping how do it secure heatwrap in the end etc thanks Quote Share this post Link to post Share on other sites
CazzaVR 0 Posted June 5, 2011 Have you used the search? Been discussed a lot! Raceland ones off Ebay are supposed to be very good at a decent price. Personally, I'd make some sort of heatshield, so the heat can escape somewhere e.g. underneath. Otherwise, if wrapped the heat will just be transferred along the exhaust and it will become VERY hot. Over time, this may cause problems. Look in the breakers' section- the exhaust heatshielding from under the car should do the job- can be cut easily and is fairly flexible. Quote Share this post Link to post Share on other sites
