jd89
Engine speed sensor location needed!!
Right guys I've been looking about but can't find it!!:-( can someone please tell me where the engine speed sensor is located please....:-)
Photos would be appreciated!:-)
Thanks
What sort of car do you have??
On the VR6 there is a Cam sensor (on non dizzy models) , a crank sensor (known as the Vehicle Speed Sensor) and one on the gearbox that feeds the speedo.
It might help, just a little , if you were to give a clue to what engine it is? :lol:
Lol too slow
Sorry...it's a vr6 93!!
It had diagnostics on it and came up with 3 faults....
Maf...been replaced
Engine speed sensor or the lambda so I'm starting with the engine sensor first.
Maf...been replaced
Whats the problem with the engine? was it scanned with the engine running?
It has problems at idle and then cuts out but drives fine, engine wasn't running when it was tested
Clean the throttle body and check for air leaks would be my first port of call.
I have already cleaned the throttle body out and done the isv, what else can I do?
  jd89 said:
Waste of time changing it then?:-(
Scan with engine running, doesnt hurt to give cam position sensor and ISV valve if your having stalling issues.
