Roger Blassberg 0 Posted June 16, 2011 I'm considering getting an "Interface" (that is, something that you and I know as a cable!!) to enable me to use VCDS-Lite. Has anyone any recommendations as to which one to get? Does it enable me to do Basic Settings? Thanks Best wishes RB Quote Share this post Link to post Share on other sites
swiftkid 1 Posted June 16, 2011 I've got an ebay cable and it works fine, can read error codes but autoscan will only let you do engine and ABS, so all I do is go into the individual modules and voila, can clear codes and read all the rest! Quote Share this post Link to post Share on other sites
elliott 10 Posted June 16, 2011 It's well worth the £7.79 plus £3.90 if you need the 2x2 adaptor. I got mine just earlier this week and its been used on three cars with great results. (corrado 2.0 16v, lupo 1.4 16v and polo 1.4 16v) Didn't work straight away, but with some help from swiftkid and some google searches it's saved a lot of headaches. Quote Share this post Link to post Share on other sites
Roger Blassberg 0 Posted June 17, 2011 Any thoughts or advice on my second question - does it do Basic Settings? Best wishes RB Quote Share this post Link to post Share on other sites
swiftkid 1 Posted June 17, 2011 What basic settings do you want? It scans, you can clear error codes by going into individual modules and you can monitor how the engine is running but its free so expect that some settings are going to be withheld for the paid version Quote Share this post Link to post Share on other sites
fla 9 Posted June 17, 2011 Swiftkid - Roger is referring to the function called Basic Settings ie when you reinstall an ecu or throttle postion sensor or other functions that require ecu adaptation. Basically the bit that makes active changes to the ecu as opposed to the measuring Blocks function which merely reads it. Quote Share this post Link to post Share on other sites
Roger Blassberg 0 Posted June 18, 2011 Thanks Hasan, as an aside, we should get together again now that I am finally back on the road with the VR. Best wishes Roger Quote Share this post Link to post Share on other sites
