ANDREW 30 0 Posted June 16, 2011 (edited) Well my VR had a slight misfire issue so I changed the coilpack and leads with new items, I thought this had solved the problem but I went out for a drive earlier and the problems is still there! It started of okay but the occasional miss came on once it was warm, then it seemed like it was only running on 5 quite lumpy at times! Where would you suggest my next port of call is for things to check? I thought maybe plugs but i've only done around 4000 miles since i had the topend rebuilt and it had new plugs then. Edited June 16, 2011 by ANDREW 30 Quote Share this post Link to post Share on other sites
DEL VR6 0 Posted June 17, 2011 from experience, i'd check the plugs. I had a smiliar problem. Morinically, i changed the coil pack and leads (due to poor advice given by Lion Garage in Hinckley - don't use them people). Turned out to be a simple case of knackered plugs. So a 25/30 quid job cost me nearly 200 quid. So, check your plugs, it's the best place to start. Quote Share this post Link to post Share on other sites
