burn-rubber-not-soul
Boggin down on g60
Hi can sum1 give me sum tip where to start
I noticed about 2500 3000 rpm it's like it's mis firing or blogging down mostly when am cruising along at any speed soon as put ya foot down gets past that 3000rpm picks up fine pulls how it should but I pull off fast theres no blog down at all it plays up now and then any help would be great
check your ignition timing,sounds off especially at these rpms
Also have you had car chipped?
you need timing gun for this.
the ignition is also ecu controlled so only happens at certain rpms.It might be your actual cam timing is out.
If it feels like a flatspot,then picks up its igniton timing or sensor going(usually hall sensor)
Check the timing first before changing any parts and check all wires to and from coil,dizzy,HT leads are all good
To check timing-
1)Pull the cover for inspection hole for flywheel off.there is 0 degree mark and mark without.this is 8' mark.put a bit of tipex on this mark so its easier to see
2)warm engine up til oil is 80c
3)turn off all electrial loads,fans,lights stereo etc
4)remove blue temp sensor plug and crank breather hose.engine tone should lower if working
5)connect timing gun,making sure trigger wire is on HT lead number one
6)rev the engine over 3000 three times to cancel hot idle function if on
7)set the revs to 2500-3000 and check the flywheel.
8)it should be between 0' and 8'. 6' is spot on.i just use 8' mark
9)if not correct,loosen M8 bolt that holds the dizzy in place then turn dizzy until timing is within the marks.
10)reconnect plug and hose
11)take her for a spin and check throughout rev range
If its not timing or it intermitally keeps jumping backwards and forwards out of timing suspect a failing hall sender
There no black smoke
Are you referring to it being the lambda probe?
