Portent 0 Posted July 3, 2011 Trying to remove a steering wheel from an old boss. It's held in place by about 6 allen bolts. Half of htem are so old and rusty that the allen key just strips the 'head' and spins. Don't really wan't to drill it at I'll probably damage the steering wheel. Any thoughts? Quote Share this post Link to post Share on other sites
Critical_Mass 10 Posted July 3, 2011 Are they flush or do they have raised heads? Quote Share this post Link to post Share on other sites
Portent 0 Posted July 3, 2011 Flush unfortunately. Otherwise I'd have hacksawed some slots into it for a screwdriver. The wheel is not on the car. I think it has been stored for some time in someones garden or garage, hence the rusty bolts. But it's old skool so I fancy trying to get it on the car :) Quote Share this post Link to post Share on other sites
Critical_Mass 10 Posted July 3, 2011 With them being flush im not sure you'll have much option other then to drill them out. Could you use a small drill bit to drill it into each bolt. Leave the drill bit in the nut then grip the drill bit with some pliers or mole grips, using it to turn the nut?? Quote Share this post Link to post Share on other sites
Portent 0 Posted July 3, 2011 Yes like that option of keeping the drill bit in. Thanks. Quote Share this post Link to post Share on other sites
Rob_B 0 Posted July 4, 2011 Trouble is you will just start to spin the drill bit out when you undo it. Or worse, snap the drill bit. I would either drill the screw head completely or get some screw extractors Quote Share this post Link to post Share on other sites
mimjed 0 Posted July 4, 2011 just got to get on with drilling them really. use the same size drill bit as the allen key you are using. countersunk heads dont take alot for the head to fall off so your unlikely to damage the wheel. then use mole grips to wind the threads out once theyre all off. Quote Share this post Link to post Share on other sites
floppyman 0 Posted July 4, 2011 You can try and use a spline tool and hammer it in.... It ussualy works. What size allen key is it? 7? And make shure you are holding the steering wheel in a vice or something very strong. Quote Share this post Link to post Share on other sites
davidwort 0 Posted July 4, 2011 or a very small chisel and tap them round Quote Share this post Link to post Share on other sites
northernvr6 0 Posted July 4, 2011 agree with floppyman get a slightley larger screwdriver or spline bit and bray it in with a hammer normally does the job Quote Share this post Link to post Share on other sites
G60_Marc 0 Posted July 4, 2011 Drill out the bolts head, then use a drill through the centre of the bolt with a bit that is smaller than the bolt. Then use a screw/bolt extractor to unwind the bolt. The bolt extractor is like a tap but with a reversed thread. As you wind it in to undo the bolt the tap's teeth bite in and grip. http://shop.ebay.co.uk/i.html?_trkparms=65%253A10%257C66%253A3%257C39%253A1&rt=nc&_nkw=bolt%20extractor&_trksid=p3286.c0.m14.l1581&_pgn=2 Quote Share this post Link to post Share on other sites
Alex_G60_Fanatic 0 Posted July 4, 2011 Drill out the bolts head, then use a drill through the centre of the bolt with a bit that is smaller than the bolt. Then use a screw/bolt extractor to unwind the bolt. The bolt extractor is like a tap but with a reversed thread. As you wind it in to undo the bolt the tap's teeth bite in and grip. http://shop.ebay.co.uk/i.html?_trkparms=65%3A10%7C66%3A3%7C39%3A1&rt=nc&_nkw=bolt extractor&_trksid=p3286.c0.m14.l1581&_pgn=2 that's what i'd be doing... Quote Share this post Link to post Share on other sites
Portent 0 Posted July 4, 2011 Thanks for the input. I've just ordered a screw extraction set and will have a go at it. Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted July 4, 2011 Those steering wheel boss screws are like cheese, even the Momo ones. They need literally, 10nm torque and that's it. Any more and they become part of the steering wheel as you've discovered. I'd be looking at replacing them with hardened steel or stainless personally. And yeah, a screw extractor is the best method. Quote Share this post Link to post Share on other sites
cheebs 0 Posted July 4, 2011 Recently I was in the need to remove some seized Allen bolts in my hatch latch and this is what I did: First, lube thoroughly with penetrating oil. Let wait at least ~20 mins. Next, freeze for ~3 minutes with either freeze spray (available at pastry suppliers) or an upside-down can of commercial compressed air. Finally, tap in a Torx key that's just slightly larger than the Allen hole, and gently but firmly turn until it loosens. HTH Quote Share this post Link to post Share on other sites
StueyB 0 Posted July 6, 2011 A slight oversized torx bit (that you potentially don't mind damaging a little) hammered into the cheese head, sorry I mean bolt head. Worked for me on many an occasion. Even when the allen key bolt head was mashed beyond recognition. I like to think of these as tricks of the trade but should only be used as a last resort. Quote Share this post Link to post Share on other sites
leeeeshad 0 Posted July 6, 2011 (edited) that's what i'd be doing... Me too, I've removed loads of steel bolts out of aluminium aircraft with easyouts, the best way IMO Edited July 6, 2011 by leeeeshad Quote Share this post Link to post Share on other sites
Portent 0 Posted July 6, 2011 Right they are off :D I first tried drilling them to allow the use of a screw extractor. But the only metal drill bits I had were part of a kit someone gave me and were made of utter cheese. They wouldn't drill into the screws (wtf!?). So I got a big hammer out and hammered in a slightly larger spline bit and managed to get that working. Now to order some new allen bolts. Thanks for the suggestions. Quote Share this post Link to post Share on other sites
Critical_Mass 10 Posted July 6, 2011 hammer, always the solution! :D Quote Share this post Link to post Share on other sites
Ben-B 0 Posted July 7, 2011 These are not just a problem with small cheese-bolts, but also much bigger bolts like seatbelt anchor bolts in some of the cars I've worked on. They were supposedly T50 but I think really they were actually more like a T51.5 and that meant there was just enough movement to allow the bit to slip and shred the bolt. Cue braying a large socket over the bolt head to break the bolt out. Not so bad with a steering wheel, but be warned, I did one of those bolts on the floor of a car and put a hole in the drivers side floor due to the excessive rust. Good job I did though, meant he got the rust sorted, and a few months later his passenger and seat fell through the car when the floor gave way Quote Share this post Link to post Share on other sites
