E16V
Worth a try. Golf van parts
Hi all. I am looking for mk2/3 golf van parts i.e the metal panels that fit where the side windows are on a std 3 door golf and the small bulkhead which fits behind the seats. Will travel. Thanks
aren't they just part of the shell pressing, i.e. a mk2/3 hatch body without the window holes punched out? I doubt there are metal panels that fit in place of the glass, for security as much as cost of manufacture.
Hi. The panels in a mk2 are riveted in and then finished smooth. Mk3 sit in the window rubber(not good for security) as far as I know. Would buy a whole van for project if I could find one cheap enough
Could do. Why didn't I think of that???? The mk2 ones have a raised section around 25mm from the edge. Shouldn't be to tricky to do I suppose. Found some new ones on ebay.com $299!!
wow that's a lot of money. Also if the bulkhead is the one I think it is you should be able to get that bent from sheet steel also.
