g60ian
g60 rev counter faulty,missing wire?
hi,finally got the car to run (usual crank pulley problem) but i have no rev counter its never worked on this recent purchase,i believe it takes its signal fron the coil?? but i have only 2 wires to my coil on spade terminals,i found a 2 port white plastic connector in the glove box that looks like it once lived on the coil but there are no loose wires anywhere near the coil ,anyone any idea,its a digital speedo version(91).also have a blanked off vacuum hose below the throttle body facing passengers side wing again cant see what it was once connected too,is this a mod or a bodge?cheers
By Digital speedo conversion do you mean its a Digifiz? Like these http://shop.ebay.co.uk/i.html?_from=R40&_trksid=p5197.m570.l1313&_nkw=digifiz&_sacat=See-All-Categories
On the coil there should be 2 wires, green and black if i remember correctly. The rev counter itself gets its signal from the ecu which is located under the rain tray in the engine bay. Vacuum hoses on the back of the throttle body: 1 should go to the ecu for manifold pressure and another should go to the active charcoal system, sometimes called the carbon canister. This system is commonly removed from the car. There is also a larger hose on the side of the boost return part of the throttle bodie that is also part of the charcoal system. If the charcoal system has been removed and the hoses for it is still there knocking about and not in use i would cut them back to about 2" from the throttle body and screw a bolt into the end of the hoses to stop any vacuum leaks.
---------- Post added at 12:06 PM ---------- Previous post was at 11:59 AM ----------
Some handy links:
http://www.google.co.uk/search?sourceid=chrome&ie=UTF-8&q=G60+Self+Study+103
http://www.google.co.uk/search?source=ig&hl=en&rlz=&q=Corrado92.pdf&btnG=Google+Search
http://www.a2resource.com/electrical/CE2.html
http://www.a2resource.com/electrical/CE2cluster.html
http://www.a2resource.com/electrical/management/digifant1.html
Edited by G60_Marc
ok only the 2 wires then thats what i have,so looking for a fault at the clocks or the rev counter itself,regarding the vacuum hoses i still have the 2 at the back of the body top one to ecu as you state other one comes round to the front of the intake manifold,and its a bigger one from the bottom thats blanked with a bolt,so thats the one for the canister? thanks for your help
