dietztho000
Putting into gear in an automatic when car isnt even on?
Exactly as title says, i can put my car in any gear including reverse without having the car on or brakedownbrakes applied, is that normal? Lol
Ignition of or on?
Might be the locking pin on the gear shift.
With ignition on and applying the foot brake canyou hear a sound on the gear shift?
No not normal. You should hear the lock engage about 1 second after you put it into Park. Check the lock under the gearshift to see it engages properly. Also, you will could see that relay 150 functions properly - this controls the immobiliser and the transmission lock.
