neuon2003
Magnex rubber hanger advice
I need to replace the rubber hangers on a Magnex and need some advice on what to use, please? I have the Magnex specific mount for the exhaust tip end (position A). Currently fitted is a motley collection of rubber hangers (A-C), per the photos below, which I think are as follows:
A=Hanger supplied by Magnex
B=Standard VR6 hanger for this position
C=Ford Transit hangers (I think)
(D=Standard VW hanger for position A and C, just for comparison.)
What do other Magnex users use? Is it OK to use the standard VW hangers in positions A, B and C, or is there a need for an alternative in position A and C as below?
Many thanks,
Bump! Can anyone offer any advice?
Thanks.
am sure on mine i used standard rubber hangers for A+C and seem to remember having one with the metal attached like your B
i have that system
im using d in the middle,b as you show for the back box and then a powerflex one very similar to a.
i have found the vag ones are stretching so im just looking for 2 more powerflex ones so then it will all be powerflex and then just that one mounting b..
i can get the powerflex number if you want but there expensive.
if that helps
The power flex ok, but i found mine sytarted to squeak after a while haha. A bit annoying.
Id say standard hangers. Whats with the transit hangers.
Thanks for the replies; very helpful. Seems like just using the standard hangers should work.
I also found two old threads of interest from 2008. One which talks about using VW heavy duty hangers (A/C) (http://the-corrado.net/showthread.php?39998-What-exhaust-rubbers-do-you-all-use&p=508358&viewfull=1#post508358) and the other with a part number and supplier for the Magnex one (A) which were £8 +VAT each http://the-corrado.net/showthread.php?38326-Magnex-parts&p=484414&viewfull=1#post484414.
Interesting opinions about the Powerflex hangers potentially being too stiff (as well as squeaky)?
I am visiting a specialist local exhaust factors and Andrew Page's to see if they can identify the Magnex hanger (A) for maybe a bit cheaper than Magnex supply.
As for the Ford Transit hangers, no idea - previous owner. When I bought the Corrado a couple of years ago, the Magnex was banging against the bumper cut-out. That was sorted with some cable ties round each of the rubbers to stiffen them up. Maybe the Transit rubbers were used as they are used to carry a much bigger/heavier exhaust, so were stiffer? Anyway, they are well past their prime now, so I'll try some new hangers.
Thanks again.
you just need the magnex bracket for the rear, the hanger is standard, i remember as i bought a bracket off the chap on here that makes them
