rolex 0 Posted July 22, 2011 Now i know i should know this, but what is the difference in the two? I know vr is wide track, but is vr wider? bolt holes in different places? Quote Share this post Link to post Share on other sites
davidwort 0 Posted July 22, 2011 main rear engine mount fixing is different I think Quote Share this post Link to post Share on other sites
dannyboy 0 Posted July 22, 2011 Yeah the gearbox mount on VR is the same shape as the rear engine mount.Four cylinders have different rear engine mount as it sits in a v-groove rather than cylinder shaped mount Quote Share this post Link to post Share on other sites
rolex 0 Posted July 23, 2011 so could you use vr wishbones with 16v subframe and have wide track? Quote Share this post Link to post Share on other sites
Erny 0 Posted July 23, 2011 Wishbone mountings n steering rack mounts are all the same, you'll need more n just vr wishbones to widen your track, you will also need vr hubs and arb and steering rack, which means you will also be changing to five stud, so you'll also want the vr rear stubs. Along with a change of wheels, and your front brakes need to be considered also as these will now be 5stud. In goin wide track you also gain a few degrees castor which is rarely a bad thing. Quote Share this post Link to post Share on other sites
