TheVims79 10 Posted July 23, 2011 Hi im new to this site and i wanted to replace the Stock Corrado Steering Wheel with a 1991 Porsche 944 RS3 steering wheel . Will that work? do i Need a Fitment Kit to make the 944 wheel to go on or will it just slide right in? Share this post Link to post Share on other sites
Chrisvw419 0 Posted July 23, 2011 My mates got an old 944 steering wheel on his B3 Passat, went straight on I'm sure. Share this post Link to post Share on other sites
TheVims79 10 Posted July 23, 2011 Thanks mate i appreciate it. Also do you know if that 944 steering wheel has an Air Bag or not? Most Regards to you :dance: Share this post Link to post Share on other sites
Chrisvw419 0 Posted July 24, 2011 The 944 steering wheel is his passat has no airbag its the usual non-turbo 4 spoke wheel. However, his dad has a later 903s steering wheel in his Golf G60. so I assume that era used the same spline type. I can't recall what the wheel you have looks like??? Although I have seen many airbag steering wheels used in cars without the airbag being used so you should be ok. ---------- Post added at 02:02 PM ---------- Previous post was at 01:43 PM ---------- Ah, think I know which wheel your on about now. If its the one I'm thinking of, it has changeable boss kits, as long as you get the model for the 944. The VW size (someone correct me if I'm wrong??) is 26mm in diameter as is the original 944 I think. The 944 could of had the smaller spline which early mk2 golfs (17mm), but that in that instance you can remove the adapter with a bearing puller. Hope this helps. Share this post Link to post Share on other sites
TheVims79 10 Posted July 25, 2011 Thanks Chris just to give you a better idea here is a copy of what the wheel looks like http://www.design911.co.uk/fu/prod1173/Steering-Wheel-RS-3-Spoke-360mm/ It actually fits almost all Porsche models its From Design 911. Click that link above and let me know . Much Regaurds Share this post Link to post Share on other sites
CazzaVR 0 Posted July 30, 2011 Lockage. Please don't start multiple threads asking the same question. As this is an 'interior' question, we'll stick with the other thread in 'Interior' ;) Share this post Link to post Share on other sites
