VWVW 1 Posted July 30, 2011 Does anyone know if the REAR corrado calipers is interchangeable between models ??? I have a corrado vr6 and just need to confirm. Quote Share this post Link to post Share on other sites
Purple Tom 0 Posted July 30, 2011 Yes they're all pretty much the same, there might be a slight variation in terms of which company made them but they will all interchange. Quote Share this post Link to post Share on other sites
16VG60 1 Posted July 30, 2011 Best choice if you are staying with oem parts is to use later MK4 golf callipers with conversion hoses to allow for different banjo bolt fitting to callipers. You could consider an uprgrade as well by transplanting the vented rears and callipers from V6 4 Mo or TT 225 etc. Sent from my iPhone using Tapatalk Quote Share this post Link to post Share on other sites
dragon green 5 Posted July 31, 2011 Best choice if you are staying with oem parts is to use later MK4 golf callipers with conversion hoses to allow for different banjo bolt fitting to callipers. You could consider an uprgrade as well by transplanting the vented rears and callipers from V6 4 Mo or TT 225 etc. Sent from my iPhone using Tapatalk Can the vented rear upgrade be done to a four stud car ? Without converting to five stud ! Quote Share this post Link to post Share on other sites
VAG-hag 0 Posted August 1, 2011 i have a set of VR rear calipers if needed? Quote Share this post Link to post Share on other sites
VWVW 1 Posted August 1, 2011 i have a set of VR rear calipers if needed? Does it include the carriers ??? and would you sell the carriers on their own. I am not sure what I want at the moment. I may go for some new ones or buy a second hand set for refurb. If you could put some pics up on condition etc and price you want for them I will put that in mind. cheers Quote Share this post Link to post Share on other sites
Critical_Mass 10 Posted August 14, 2011 i'll be after the drivers caliper if that helps? Quote Share this post Link to post Share on other sites
