VWVW
Rear Calipers on corrado are they interchangeable
Does anyone know if the REAR corrado calipers is interchangeable between models ??? I have a corrado vr6 and just need to confirm.
Yes they're all pretty much the same, there might be a slight variation in terms of which company made them but they will all interchange.
Best choice if you are staying with oem parts is to use later MK4 golf callipers with conversion hoses to allow for different banjo bolt fitting to callipers. You could consider an uprgrade as well by transplanting the vented rears and callipers from V6 4 Mo or TT 225 etc.
Can the vented rear upgrade be done to a four stud car ?
Without converting to five stud !
i have a set of VR rear calipers if needed?
Does it include the carriers ??? and would you sell the carriers on their own. I am not sure what I want at the moment. I may go for some new ones or buy a second hand set for refurb. If you could put some pics up on condition etc and price you want for them I will put that in mind.
cheers
