ANDREW 30
VR6 MAF quick question
Depends which maf you have, there are two types.
Early vr 6 pin plug (5 terminals) hot wire type.
Late vr 4 pin plug thin film type..
They are not interchangeable without ecu swaps.
I think '94 should have the 6pin type.
But the 4pin type is better for forced induction and is easier to run a 4" maf tube.
Any I think both types were used on the AAA.
Yep mine has the 6 pin MAF, so if the AAA MAF has 6 pins will it be the same part and compatable with mine?
Yup
