paxman
Golf VR6 cylinder head on Corrado VR6 engine?
Does this work/fit?
I have searched on here but could find anything relevant (altho am only using tapatalk on iPhone)
Cheers guys
Head should work, just the block bore sizes are different, 2.8-2.9. the corrado cams are the best to use. I'm in the middle of a engine build, and have got a reconed Mk 3 head with corrado cams, which I have been told will work. ( it better).
Edited by aust
On my old Corrado VR6 - I replaced the head with a reconditioned head from a Golf. They will fit, but you may find slight differences & the cams are different, so should be swapped over, as mentioned above. On the one I got, it had a hole in the head for some kind of EGR setup I think. This had to be plugged when fitted to the Corrado.
Cheers,
Robbo
