Ruggy
280mm calipers/carriers, which donor?
I'm wanting to upgrade my brakes to 280mm, as understand it I can use the calipers/carriers off a G60 or VR6 & then buy 280mm discs. From memory my old mk3 Golf gti also had 280mm brakes so would I also be able to use calipers/carriers from the mk3? As these cars were quite common I'm counting on there been more parts out there and therefore cheaper than buying somebody's G60 set up.
Cheers
i have some 280mm carriers sat in the garage and you could have them for £15 posted if you need them.
i recentely cleaned all the corrosion off them and they probably need a quick wipe and ready for painting
Sounds good to me. As I understand it, I can use 280mm carriers with my smaller calipers and then fit 280mm discs?
If that's the case I'll bite yer hand off for those carriers!!
Here are the photos i said i'd get, they look quite dark in the photos but are metal coloured in real life.
---------- Post added at 11:39 AM ---------- Previous post was at 11:38 AM ----------
btw, i will check what the postage will cost, as last time i posted something and made up a price i stitched myself up
