Alex_G60_Fanatic 0 Posted August 31, 2011 just reads 99.9mpg all the time... checked the back of the clocks and the vacuum hose was attached and looked fine... where does the hose go to in the engine bay and what else could be causing this? :thumbleft: Quote Share this post Link to post Share on other sites
owen g60 10 Posted August 31, 2011 It's one of those weird corrado gremlins. It usually sorts itself. Could always try resetting the clocks by disconnecting the battery Quote Share this post Link to post Share on other sites
boost monkey 0 Posted August 31, 2011 there's vac lines going into and out of both the clocks and the engine, my brother from another mother. Get under that hood! I think there might be some info on this site about it. If only someone designed a search. p.s. you owe me cake. Quote Share this post Link to post Share on other sites
Alex_G60_Fanatic 0 Posted August 31, 2011 It's one of those weird corrado gremlins. It usually sorts itself. Could always try resetting the clocks by disconnecting the battery I've already had the battery disconnected loads of times... It's not working since I bought the car there's vac lines going into and out of both the clocks and the engine, my brother from another mother. Get under that hood! I think there might be some info on this site about it. If only someone designed a search. p.s. you owe me cake. No cake for you! I know there is a vac line in the engine bay but where is it? Quote Share this post Link to post Share on other sites
owen g60 10 Posted August 31, 2011 The vac line on mine runs across the top of the head by the intake and isv Quote Share this post Link to post Share on other sites
Alex_G60_Fanatic 0 Posted August 31, 2011 The vac line on mine runs across the top of the head by the intake and isv there are loads of vac pipes there though... which one is for the mpg? Quote Share this post Link to post Share on other sites
