krishen 2 Posted September 17, 2011 (edited) I was driving home today and as i got in traffic noticed the coolant temp jumping up. Normally sits at about 90. Pulled over and realised i could't hear the fans. I had just picked the car up from the garage (new clutch fitted) so hoping that its just a case of the switch/sensor not being plugged in. But as i went to open the bonnet realised the cable has come away from the handle so unable to get the engine bay just yet. Question is i need the car tomorrow. Will it be ok (motorway all the way) if fans are not kicking in? Edited September 18, 2011 by krishen Quote Share this post Link to post Share on other sites
monzablau16v 0 Posted September 17, 2011 personally i wouldnt simply because if you get stuck in traffic on the motorway it will cook itself fairly quickly (well my VR gets toasty after a long blast!) is it a VR6 / G60 / 8v / 16v....? if its a VR6 then check this guide on how to test everything: http://the-corrado.net/showthread.php?38925-The-definitive-VR6-cooling-guide Quote Share this post Link to post Share on other sites
krishen 2 Posted September 17, 2011 personally i wouldnt simply because if you get stuck in traffic on the motorway it will cook itself fairly quickly (well my VR gets toasty after a long blast!) is it a VR6 / G60 / 8v / 16v....? if its a VR6 then check this guide on how to test everything: http://the-corrado.net/showthread.php?38925-The-definitive-VR6-cooling-guide Its a VR6. Before i can start testing i need to get the bonnet open. Quote Share this post Link to post Share on other sites
monzablau16v 0 Posted September 17, 2011 try this: http://the-corrado.net/showthread.php?57415-Bonnet-release-has-snapped&p=736783&viewfull=1#post736783 Quote Share this post Link to post Share on other sites
krishen 2 Posted September 18, 2011 Ok managed to get the bonnet open and found there is nothing plugged into the fans. Had a look around and couldn't find the wire the plugs in anywhere :-( So can someone point out where it comes from? I assumed it came off the same loom as the switch that goes into the radiator but couldn't find anything on or near that loom. Quote Share this post Link to post Share on other sites
