Stonejag
312mm brakes, working yellow temp sender
Hi all,
I need a yellow 4-pin temperature sender for a '95 VR6; the one that goes in the thermostat housing. Must be tested working! (3 of the clips that hold the sensors in would be good too).
Also has someone got a big pile of all the bits to do big front brakes and mk4 rears? Don't really know what I'm doing so really I'd like to buy enough bits that I can hand them all to the garage and tell them to get on with it :D
Cheers
Stone
Can do the temp sender and the clips, have got two temp senders so if the first one is dud I can send you the second, can send you three clips, metal or plastic? Tim
If you punch in to eBay Audi tt 312, these a guy who sells calipers, carriers, disc and pads for £250, all you'll need is the spacers longer bolts, larger back plates and hoses. Hope this helps
Top tip, thanks for that! Will these hoses do me for a front and back conversion?
Sorted for a sender now, thanks Tim :)
Stone
