Tristan H
alignment figures? edit... need bushes now!
Going to check out the angles of the dangles on the 4 corners of my C tomorrow , anyone point me in the direction of what the best set up for road use is? thanks
Edited by Tristan H
1995 16v. Runing a standard OEM suspension or modified, if modified how? Just shocks or lowered?
1995 indeed , on Weitec coilovers , with oem 15in wheels , 195/50 15s . but only dropped about 30mm . it has a tendency to pull to the left , and to tramline over white lines . Going onto the lift this evening to have a good prod at all the suspension bushes and then re-align it . Just wondering are the settings from VW the best? I know on my old IS200 that the Lexus ones used to eat tires off...
cheers Jay , that's kinda what I had in mind for a FWD-er , and then trim the toe in or out after a few weeks depending on how the tires are wearing . I'd be aiming for a half degree neg each side...is that what you mean by a degree of neg , or did you mean a degree each side?
I tend to run 1 degree negative each side minimum. Always found it helps when you load the front end up a bit.
Tyre wear is pretty much always down to toe, which, assuming all the bushes etc are good, is why I run paralell.
Jay
well , figures are gone out the window .... I need a LHS inner tie rod , and a RHS rear wishbone bush! Fit to fall out of it! OOPs..... One of the rear axle ones is a little tired looking too.... What are the best bushes to replace them with ? OEM , ones from other VAG cars , or Poly? Bear in mind its mostly country roads.
I would go all OEM apart from the front wishbones, where I would put R32 ones in the back of the wishbone and powerflex in the front of the wishbone.
Jay
At least if they found that much wrong with it that explains the handling - do all the bushes as above and it will be great!
Assume it's been a while since the MOT too?
Jay
what exatly makes the R32 ones better , are they stiffer?
Found all that myself! S'funny , it's not all that long since it was tested......someone musta known someone in the test centre...
is this 8N0407181B the bush part/number?
