xcore
running with temp sender unplugged?
as above cured a problem with my 9a corrado (wouldnt idle or rev) by unplugging the white sendor, is it ok to run it like this till sat when i can get a replacement?
cheers
you will find your fuel economy etc will be crap as your ecu will go to a predefined map rather that taking the sender values to map
