Redfox
abs problems, rearbrakes
Hi all,
Helping a friends 2L.16V 1993 ...P...) out, abs brakes but no eds. Been swapping the pressure regulator valve in front of the abs unit out (the one for the rear brakes. Also swapped the hydraulic pump (motor) and the pressure accumulator, but to no solving. The problem is, that it couldnt brake on the rears first. Then it developed a nonexsistent brake servo help, as the electric engine took off. Then we changed the aforementioned parts, and we have again an engine that spins, and brakes the front brakes, but won't let out any pressure to the rear brakes.
Followed the ideas mentioned in the Bentley manual, but didn't sort it completely.
Any ideas?
Cheers,
Redfox.
okay copied over to drivetrain section.
eds: electronic differential system, VW's version via abs block.
Cheers,
Redfox.
Note: I have copied this question to drivetrain.
