emu
VR6 rocker cover breather filter
The description says 9mm internal diameter which would be too small for the vr6 Rocker cover, these look like the ones available in halfords.
As for using them, if your car is your daily your better off with an oil catch tank which continues to be connected to your induction system, problem with these on dailys is breathing in oil vapours when the blowers are on and you can end up with oil all over your engine depending on the condition of your oil. if it's just a case of you want it to look nice and your cars well looked after then there fine. You will also have to plug a hole in your induction pipe were the pcv valve was previously.
thanks for answers, now I know I won't be fitting it, just was wondering if it's a good idea of fitting it or no.
