vagingit.co.uk
g60 lambda part number
Ive been searching on here and on the rest of the internet for the correct part number for a G60 Lambda sensor/probe
Its for an early spec G60.
Does anyone know what it is? Ive found so many different numbers
was your g60 fitted with a cat from the factory?
VW part number for non cat models: 037906265
there are 3 options for models with cats.
lambda probe / F >> 50-K-011 579 3 pin part no:030906265
lambda probe / F 50-K-011 580>> 50-K-030 000 part no: 037906265B
lambda probe / F 50-L-000 001>> 5 pin part no: 037906265B
If you search on here using the title of this thread there is quite a lot of good info - this for example...
http://the-corrado.net/showthread.php?36921-Corrado-Lambda-Sensors-Bosch-Part-Numbers&highlight=g60+lambda+part+number
