krishen 2 Posted January 8, 2012 In need of both please. The door pin is the metal rod that sticks out the door card and goes to the white plastic clip. Also need the central locking module located behind the rear drivers side quarter panel. Thanks Quote Share this post Link to post Share on other sites
Pete 0 Posted January 8, 2012 Hiya, I have both I think lol. I have a spare door pin module which has the metal coat hanger type pin going into a white plastic box of tricks. I also have a full c/l pump if that's what you mean? It's encased in rubberised foam. Let me know if it's what you want etc. Ta. Quote Share this post Link to post Share on other sites
rodmax 0 Posted January 8, 2012 Hi i have both of the parts you need,but can you supply the part no off your old pump as there are different ones used let me know rod Quote Share this post Link to post Share on other sites
krishen 2 Posted January 8, 2012 Just to be clear im not after the actual pump itself (white in colour) thats is fitted in the doors. I need the control module located behind the rear drivers side door card. Think it has 3 or 4 sets of plugs going into it. Will try to get the rear panel off tomorrow to get a part number. Quote Share this post Link to post Share on other sites
dazfxvw 0 Posted January 9, 2012 I have the window control module (the correct one that is fitted behind rear quarter card) £15 + postage (£2.50) so £17.50 all in. Let me know if you want it (preferably by call or text) 07951 244 255 Daz Quote Share this post Link to post Share on other sites
rodmax 0 Posted January 9, 2012 Hi again i have these parts ,but again there is a choice down to part no thanks rod Quote Share this post Link to post Share on other sites
krishen 2 Posted January 10, 2012 Guys heres the a pic with the part number. Let me know if it matches up with what you have. Thanks Quote Share this post Link to post Share on other sites
rodmax 0 Posted January 10, 2012 Hi,will check mine & get back to you rod Quote Share this post Link to post Share on other sites
dazfxvw 0 Posted January 17, 2012 Yes this is the same as mine, price as above ^^^ Quote Share this post Link to post Share on other sites
