Salcombe Webdesign
Missing part
Hi All. I was having a little tinker around with the VR6 this morning and noticed a missing adjuster bolt on a part on the left of the engine (your left as you look at it from the front of the car), above the Aux belts.
I'm a newbie so was only just about to learn how to do my own oil change, so I have no idea what this part is.
Can anyone shed any light? It kind of looks important,lol.
Ash
[ATTACH=CONFIG]51272[/ATTACH]
If you're talking about the bolt hole that looks to be about central in the picture, then that's part of the auxiliary belt tensioner and there isn't meant to be a bolt in there. You're only supposed to put one in when you want to slack off the belt tensioner prior to removing the auxiliary belt :)
Its supposed to be like that fella, its for releasing the tension on the aux belt.
EDIT
We'll call that a draw Dave :-)
Rest easy fella there is nothing missing. The component in your pic is the auxiliary belt tensioner, and the thread will accept a bolt as and when you require to de-tension the system for belt removal.
Cheers. Just found that on the engine diagrams as well. Only thing is the part the bolt then pushes on has snapped off and I have a little piece of metal floating around in there. So this will be fun when it comes round to time to change the belt.
