owen g60
G60 airbox info
Hi guys
probably quite a simple question.
What size is the hole on the air box that the charger connects to??
My gut feeling says 79mm
also what angle hose would i need to get to do this??
Im asking as i have a 63mm outlet plate made for it and would like to attack it to the air box as the original hose is splitting and i dont want to get and crud in the charger for obvious reasons
Thats a good question! Racking my brain I'd assume it to be 76mm rather than 79mm. Think I've got an original hose in my dads garage if you need one.
By 63mm outlet plate do you mean an rsr? Or is it for the intake side of the charger?
i had a plate made a while ago when i first did my front mount intercooler.... think its in my thread.
I have now deleted the boost return so am thinking of using this plate and a silicone bend to join it to the airbox.
Im thinking 45 degree bend somewhere between 75 and 80mm on the airbox side
