hyland770
whats this pulley for?
That's the crankshaft pulley and it shouldn't vibrate. It could be the crankshaft pulley bolt (the one in the centre) loosening which can lead to damage to the crank nose. You could also check that the four allen bolts are tight as they hold the pulley too the timing belt pulley behind the one in the picture. If I remember correctly there is also a rubber damping strip built into the pulley which may be deteriorating. Best thing to do is pull it off and carefully check everything.
Have a look here http://direct.the-corrado.net/showthread.php?55045-Fate-tempted-and-it-retaliated&highlight=%2Bcrankshaft+%2Bpulley
