owen g60
G60 ECU relay repair
Couldn't find a thread on relay repair so thought I would make one.
1: Remove the relay from its position
2: Sit it with terminals facing up
3: Prise it open using a small screwdriver on the 2 securing clips
You should end up with this
4: Remove the plastic base plate and wobble the terminals you will probably find a couple loose.
Look at the corresponding solder joint on the under side of the board. The loose pins will have a crack in the solder.
5: Desolder the pins
6: apply fresh solder
7: Reassemble the relay when cooled.
8: Refit to relay panel.
This should work with 99% percent of relay types.
And you should never have to buy a relay again
Enjoy
one of two methods.
1: Solder sucker... heat the solder with a soldering iron then quickly use the solder sucker to suck up the liquid solder.
2: Solder wick.... lay it over the solder then heat with the soldering iron and it will soak up the solder
