Sam.l 0 Posted February 25, 2012 Hey guys, I want re-trim the inn sunroof cover and thought I could get it out by removing the light and rubber seal around the edge but to no avail. would i need to remove the whole headlining? any help would be appreciated. Thanks in advance. Quote Share this post Link to post Share on other sites
floppyman 0 Posted February 25, 2012 I think you need to take the sunroof panel out Quote Share this post Link to post Share on other sites
dragon green 6 Posted February 25, 2012 Sunroof stays ! Take out the headlining,raise the sunroof,there's an alloy spring clip on each side(looks like half a clothes peg )compress this, the lining then drops flat. Close sunroof. Lining can then be slid to rear of car, a twist 90degrees and it slips out ! If you use the search, you will find some good guides on here ! Good luck Quote Share this post Link to post Share on other sites
Sam.l 0 Posted February 25, 2012 Again, tried using the search but couldnt find much! im probably using the wrong key words. Thanks for the info dragon green, much appreciated. i was hoping that i didnt have to remove the headliner but oh well ha. Quote Share this post Link to post Share on other sites
dragon green 6 Posted February 26, 2012 Since the forum move, I've been struggling with the search for sunroof threads ! Found this on Vortex http://forums.vwvortex.com/showthread.php?p=76078788 Quote Share this post Link to post Share on other sites
