cobbvo
what subframes will fit my g60
Hi guys my subframe( the one a the rear of engine bay ) has got some rot can anybody tell me if its the same as a mk2 golf aslo will all the other corrados fit ? Cheers
4 cylinder corrados only, golf ones don't have the extended tails bolting under the floorplan, VR6 ones are different too as they have a different rear engine mounting point and wishbones
yep, any year, it's possible very early subframes don't have the 'c' shaped locators for the wishbone rear bushes but I've never seen one without, only on mk2 subframes and then you just need the little expanding sleeve around the wishbone bolt instead if that is the case.
If it's a late G60, could it have the VR6 stuff on it? 'N' Chassis onwards? I'm almost sure it would have?
Edit: Owning a late G60 isn't half confusing at times! I may have it wrong thinking about the engine mounting position? Just thinking aloud really...
Edited by Riley
No, although late g60s had the facelift bonnet and wings etc. they still have the mk2 based running gear, only the vr has the mk3 gti 'plus' axle
