d3927 0 Posted March 26, 2012 Will be fitting reconditioned box this week, i know it takes 2 litres but what oil type is best, i have some mobil 75w 90 fully synthetic, will that be ok? Quote Share this post Link to post Share on other sites
nrc 0 Posted March 26, 2012 I was going to get some Redline MT90 following recommendations I've read on here. Quote Share this post Link to post Share on other sites
dragon green 5 Posted March 26, 2012 Another vote here for Redline MT90 Quote Share this post Link to post Share on other sites
DriverVR6 11 Posted March 26, 2012 Redline MT90 is the best stuff imho. Quote Share this post Link to post Share on other sites
d3927 0 Posted March 27, 2012 Cool, cheers, just bought 2 litres and will be back on the road next week hopefully!!!! Quote Share this post Link to post Share on other sites
G-Lad 0 Posted March 27, 2012 Top tips (apologies in advance if you already know this!): Get the fill plug out before you remove the drain plug. Drain when warm or like me you won't get it all out. Lastly, fill from level ground using a long bendy piece of hose into the fill hole, or you will over fill unless you jack both front and back of the car. This is because the fill hole should be filled to the brim if level. You'll be surprised how a few degrees makes all the difference to burst oil seals. ...enjoy the improvement! Quote Share this post Link to post Share on other sites
d3927 0 Posted March 27, 2012 thanks for the advice bit worried about oil seals, i am fitting a reconditioned box should i fill it with the 2 litres before fitting it, should be easier and i will then know for definate the right amount is in ??????? Quote Share this post Link to post Share on other sites
G-Lad 0 Posted March 28, 2012 I wouldn't worry too much, but I would do your best to get it right. The trick is that when fitted, to fill to the point where oil stops running out of the fill hole. tou could fill a new oil-free recon box before you fit, but it'll be heavier. if I was fitting a new box, i'd want to refresh the oil fairly soon after, like you would with a recon engine. The wear on new gearbox parts may not be as big as for an engine, but either way you'll need to get used to filling it fitted anyway. since you're filling from perfectly empty, you will know there is none already inside. When you drain it next time, just note how much comes out before blindly trying to cram more than that back in, or you'll overfill for sure. good luck :) Quote Share this post Link to post Share on other sites
delfinis38 1 Posted February 25, 2013 i know it takes 2 litres but what oil type is best Just about to order some redline MT90 for my manual gearbox (VR6 Engine), can anyone who has done the job tell me exactly how much oil is required please........ I've done a search on the forum and come up with three different answers.. above says 2 litres....... Wiki says about 1.5 litres and another post on the forum says "I ordered three bottles". there is no mention of the amount in my car manual either... So do I order 2 Quarts or 3 Quarts.... ie...2 bottle or 3 bottles..... thanks for any help.... don't want to buy too much or too little..... the box looks too bit to hold less than 2 litres. Quote Share this post Link to post Share on other sites
VAG-hag 0 Posted February 25, 2013 2 bottles and you should have a little left over mate. Quote Share this post Link to post Share on other sites
GlosterOx 0 Posted February 25, 2013 Agree, 2 Lts is ample. Ian. Quote Share this post Link to post Share on other sites
