CazzaVR
Breaking Late Spec 2.0 16v Black Interior *Can bring items to Bristol Volksfest*
Last thread was to big, so here's a new one!
Late spec 2.0 16v with black cloth interior, stainless exhaust, sports cat (>£300 when new in 2006) etc etc. Engine runs very, very well. Smooth gearchange with no crunching. Lots of pics to come soon.
We will list parts as we take them off. Please feel free to make requests.
All prices are posted unless otherwise stated Collection welcome!
Interior switches, electrics etc tested and fully working:
Late 16v Clocks (full working order, showing 119K) - £40
Headlight switch - perfect working order, all tabs intact £15.00
Fog light Switches - working order £12.50
Rear Demister switch + blank - working order £10 - SOLD
ABS Light - - working order - £15 SOLD
Spoiler switch - £10
Blank switch face - £5 - SOLD
Rear Boot light - working order - £6.50
Driver's double window switch - £12.50 SOLD
Passenger single window switch - £10 SOLD
Driver's grab handle + mirror switch - £15 SOLD
Interior light & sunroof switch (the bigger 'pull-down' version) - £15
Kenwood W8531 CD/Receiver (50 watts, RDS, AM/FM, Face off, customisable display, remote) - perfect working order - £30 - delivered
ABS Controller - £25
Window control module £20
Assorted relays POA
Central locking pump -with foam and strap if required - £17.50
Interior seats and trim:
Black cloth interior (no hump), good condition, slight driver's bolster wear - £80 - SOLD
Heating vent grills - full set, good condition - £3 each or £10 the lot - SOLD
Sun vizors, good condition, courtesy mirror light working - £22.50
Cigarette lighter and mounting - £8.50
Ashtray and mounting - £5
Black grab handle, good condition - £10 - SOLD
Speedo surround (left corner plastic broken but does not show or compromise a good fit) - £10
Complete seatbelt set - £25
Top of door card plastic trims - both sides - perfect - £25
Passenger side door pull/grab handle - - good condition - £10 - SOLD
Inner Door release surrounds - £7.50/each (Grab a bargain - these are £50 each from VW!) - SOLD
Black Cloth Late Doorcards - good condition 2x front/2x rear - £40
Passenger Interior door triangle - £8
Headlining, standard beigey/grey colour (x2), good condition - £15 ea Collection only please
Sill plastics (both sides) £15
Gear stick surround, gaiter and knob (non standard 'dimpled' gaiter and knob but nice) £15
A-pillar trims (each has one tiny hole where the alarm sensors were mounted): £15 the pair
B-pillar trims: £20 the pair
C-pillar trims: £20 the pair
C-pillar joining trim: £10 SOLD
All above trims (A, B, C): £40
Passenger Parcel shelf support inc speaker (VGC): £17.50
Centre tunnel plastics (for 4 cyl cars without rear seat hump) 3 pcs, very good condition, all securing clips present: £20
Rear ashtray: £10
Dashboard- VGC (no holes etc): £50 collection only please, or can take to Bristol Volksfest.
Engine Bay:
Strut Mount plastic covers - £3.50 SOLD
Washer bottle x 2 - £7.50 each
Headlight/airbox plastics (2 bits from between headlight and airbox) - perfect - £10
Throttle body: £20 delivered
Upper manifold: £30 delivered
HT lead holder (all clips present!) + lead puller + clips + brackets: £12.50 delivered
Distributor: £40
Metering head (see post #6), excellent condition (inc rubber/metal fuel pipes, 5 injectors): £40 delivered
Lower airbox (drilled) + warm air hose: £25 delivered
Manifold heatshield + warm air hose attachment: £10
ISV- excellent condition! (oem, looks very recent): £25 delivered SOLD
Fans/Radiator/fan switch/rad cover: £40
Radiator air guides (2pcs): £10
Starter Motor: £20 SOLD
Slam panel (flash red): £30 collected
Exterior:
Aerial £5 SOLD
Aerial Base + Gasket - good condition - £12.50
Petrol flap - good condition, no rust, spring intact - £15.00
Fuelling grubber - good condition - £5.00
Rear lights (4pcs, VGC) - £40 SOLD
Headlight - Driver side good condition all tabs etc but very light chipping to bottom of glass £30 SOLD
Headlight - Passenger side - all tabs intact £40 SOLD
Front Indicator - drivers side - 2 very small cracks (see pic) £12.50 SOLD
Front Indicator - passenger side - 1 very small crack not very noticable (see pic) - £12.50 SOLD
Front fog - very good condition SOLD
Front Grill - only has the middle upper tab but holds fine - £12.50 SOLD
Flash Red Corrado script rear badge - good condition (all tabs intact) - £9.50
Bonnet - good, straight condition, could do with a respray - £40 collected
Drivers Door handle and key (fitted with the Dave16v repair kit so won't break again!) - £25 SOLD
Wing Mirrors, good condition (both sides) £20 each
Side mouldings, good condition - full set £30
Passenger side door handle with key - £25
Drivetrain/Brakes/Suspension etc:
4-stud spacesaver - £25 SOLD
Front engine mount: £15
Misc:
Tool set - £32.50
Document Wallet (inc instruction manual but excluding service book) £12.50
Tailgate gas struts - pair with all fittings in good condition - £20
PM myself or Vornwend with requests.
Edited by CazzaVR
Bump. All prices o.n.o.
Let me or Vornwend know if you need anything currently not listed.
Hi Steve,
No straps I'm afraid- both broken :( The space saver is indeed 15" 4-stud, in good order.
OK mate- will pm you details.
---------- Post added at 8:44 PM ---------- Previous post was at 8:08 PM ----------
Still have it :)
Do you still have the aerial base and gasket?
[ATTACH=CONFIG]59457[/ATTACH]
Sorry to be a pain: not sure that what I have is standard! Couldnt pm cos I couldnt seem to add an attachment.
This is what I have now. A banjo fitting to the base. At the other end of 2m of cable this cylindrical fitting screwed to the end of the coax cable from the radio. Is this standard or aftermarket? I was told the base contained a pcb- mine has a spring. I expected a tail on the base with normal male/female coax connectors.
So are you able to tell me if your base is the same as this. If it is whats the price inc postage-is the gasket still OK or about to disintegrate?
do you still have
price delivered to SM4
THANKS
Hi, I'm after all the carpet retainers for a black carpet and the front doorcard retaining clips which hold the bottom of the doorcards. Please let me know if you have any?
Chris
do you still have
THANKS
Sorry mate that's now sold
---------- Post added at 5:22 PM ---------- Previous post was at 5:20 PM ----------
any more details on the stainless steel exhaust?
Dave
Sorry mate that is now sold
---------- Post added at 5:25 PM ---------- Previous post was at 5:22 PM ----------
Chris
I don't think we have any carpet retainers left but pretty sure we will have doorcard retaining clips - how many do you need? - 50p/each posted ok?
Looks aftermarket to me- as you say, you should have two connectors- male and female (like ours). Gasket is good.
---------- Post added at 11:46 AM ---------- Previous post was at 11:45 AM ----------
Should be off this weekend- will have pics etc then :)
Dave
I need 3, 50p is fine. let me know.
Okey dokey we will try and get these off for you on Saturday. I'll PM you when we have them ready
Patric- will need to look. Should have clips, but don't think we have the scraper.
Peter- mirror's gone, but still have the door if you're interested. It's pretty bare, but still has the window + mech. Wouldn't want much for it...
