vr6paul
Rocking chair
My drivers chair has a habit of rocking now an again.
It is as if one of the bolts at the back right hand side of the seat is worn/broken/missing.
Anyone have any ideas of casue or hot to sort it?
It is a bit un nerving when it lears forward and to the left going round some corners.
Any help please
cheers much guys
Paul
Sounds like one of the white plastic guide clips is broken/missing. They're about 70p from the dealer. There's also a orangey/yellow 'buffer' at the front of the seat where the travel stop bolt is. Check those out.
K
Yeah.. fairly easy tho, remove the plastic covers from the guides then put the seat to its lowest setting, undo the bolt at the front and slide fwd to release
...undo the bolt at the front and slide fwd to release
Erm, Slide BACKWARDS to release the seat! :roll: :lol:
Maybe Supercharged meant that you should hold the chair in a static position and slide the car forwards ;)
Now that I gotta see... :D 8) :lol:
Guys... I stand facing the rear of the car and slide the seat forwards... :wink: ..or is that backwards :?
